92 green mtx black full leather
marv
chicago
I am parting this car and it has a ton of stuff so here is a list of aftermarket
Dynomax catback with mid pipe and new mufflers $300
b&M adjustable rear control arms- $100
Asfb cup -$75
Stock stuff
3.0 injectors-$10 each
24mm front sway bar-$50
26mms rear sway bar-$50
92 engine wire harness-$50
92 heads-$100
92 subframe -$50- pu only
Low mile trans mount -$30
ac delco wires less the 5000 miles-$50
new coil pack -$50
92 radiator cooling fan-$50
ccrm -Manual-$50
right fish tank very nice clear $50
mtx accy. belt pulleys with good bearings
2- 4 rib $40 each
2-6 rib $40 each
3.0 oil pump136k-$75
Sony explode radio with wire harness for front and back-$75
92 slicer rims-$25 each local pu
97 star rims-$150 for all 4 local pu only
Feel free to ask me for any other parts because I might have them.
droptSHO
Wheaton, IL
Where are you at in Chicago? Interested in the 96 brakes with knuckles and the BBBs.
marv
chicago
If anybody would like anything specific and are coming to Chicago let me know and I will have it ready.
tompumped
VT
How much do you want for the blower motor control module (relay) shipped to 05743?
tompumped
VT
I meant blower motor resistor. Also how did the hand porting come out on the intake? Were you happy with the quality? I might be interested in the intake and bbbs
Joe_SHO
ND
I want the engine. Price shipped to 58503?
shonuffswole
chicago heights illinois
Is the ignition control module still available? I need one for a 1995 MTX SHO. Also looking for engine motor mounts if you have them. I live in the Chicago suburbs
SHO~OFF
Acworth, Ga. 30102
I am parting this car and it has a ton of stuff so here is a list of aftermarket parts:
big bore butterflies-yellow color- $125----sold
sho source crank udp- $150---sold
ribbon style lpm-fan turn on 190, ported intake,engine 3.2- $75
Nitrous kit Zex dry #82011 complete with all wiring- $300---sold
Nitrous express bottle heater - $50----sold
Stainless steel brake lines $60-sold
96 brake upgrade, knuckles and calipers with brackets-$200-sold
low mile sho source reinforced front motor mount-$125
low mile trans mount - $30
reinforced rear engine mount- $85
rod shifter rebuilt with sho source kit- $125
Asfb cup style-$75
Hand ported intake with full gasket matching-$100---sold
The engine 3.2 from 95 with rockauto crank with new undersized main bearings and rod bearings
this engine has 120k with only 14k since engine rebuild- short block $300
MTX Trans with 120k $300
Stock stuff
new coil pack less then 100 miles-$50
Ignition control module less then 100 miles-$100
92 Rebuilt Alternator-$50
92 Rebuilt Starter-$50
x2j PCM not remanufactured-$75
ccrm -Manual-$50
2- 4 rib $40 each
2-6 rib $40 each
mtx stock lower mile axle set-$75
stock harmonic dampner good shape not loose-$40
timing sprocket-$40
3.2 oil pump 120k -$100
Cam chain tensioners- orange, not much wear-$150
Do you still have the motor mounts? And do you have an under drive pully For a 91?
ShoOff93
Ft Myers FL
Do you have the dash? If so is it all cracked up? Thanks
Sent from my SM-N910P using Tapatalk
taurus_shotime
Greetings from Stevens Point Wisconsin. I have a '91 and need both the A Pillars (assuming they are black) if they are available.
TheVancen
Ontario
Asfb cup style-$75
MTX Trans with 120k $300-sold
Stock stuff
ccrm -Manual-$50
2- 4 rib $40 each
2-6 rib $40 each
timing sprocket-$40
Any chance you'd be willing to sell some
Do you know if the radiator core support on your Gen 2 is the same as the one on a Gen One? I was involved in a front end collision last week and need a fresh one. Also, would the radiator and oil cooler work as well? If they do I am jnterested in all of these parts.
marv
chicago
I just added some valve adjustment tools plus shims and hard button eatc.
broke1
Alabama
Sent you a PM.
Also,could I get some pics of the b&m rear control arms?
Thanks!
