GEN 3 SHO FAN
Hi,
I'm a gen 3 owner and I'm searching (a lot) a in-between non-lowering solution for Ford rear springs that are too soft and Moog CC859 that are too strong for me. (Just want a little stiffer rear end and resolve SAS.)
I know for reading here sometimes that some Gen 1 and Gen 2 guys do good tricks with springs. On gen 3 section, it's very quiet on this side. Maybe someone here have the knowledge to verifying if Moog cargo coils CC697 can fit on our cars ? I tryed to put all necessary infos. Also, I'm not sure what small changes does on inner diameter, free height, installation height (what that's will do on spring behavior) if someone have some time to explain this.
Possibly a softer solution for cargo coils Moog CC859, the Moog CC697.
Moog rear cargo coils CC859 (progressive)
capacity : 455 lbs
spring rate : 137-349 (!) lbs/inch
wire diam. : 0.59 (0.60 measured)
1.57 cps
inner diam. : 5.22
free height : 14.50 (Ford stock is 15.88)
installation height : 11.25 (Ford stock is 10)
ends : 2 tangentials
Moog cargo coils CC697 (progressive, rear Olds Intrigue 2000, fwd 3.5l)
capacity : 680 lbs
spring rate : 122-....(300?) lbs/inch
wire diam. : 0.56
? cps
inner diam. : 5.42
free height : 15.81
installation height : 9
ends : 1 tangential, 1 pigtail
Note : cutting the the pigtail end will be required (around 1 turn or a little more)
Moog 80096 (Contour linear front springs)
capacity : 680 lbs
spring rate : 120 lbs/inch
wire diam. : 0.56
1,40 cps (estimated)
inner diameter : 5.71
free height : 15.88
installation height : 10
the link of all my searches :
http://www.shoforum.com/index.php?t...esh-what-are-the-options-cc859-review.133054/
Thanks for your help,
capacity : 455 lbs
1.57 cps
inner diam. : 5.22
capacity : 680 lbs
wire diam. : 0.56
? cps
inner diam. : 5.42
free height : 15.81
capacity : 680 lbs
wire diam. : 0.56
free height : 15.88
