hi all,
i finally finished the '96 upgrade with drilled and slotted rotors and raybestos premium grade ceramic pads all the way around. after i did the fronts the brake pedal was fine. when i finished the rears i pushed in the pedals a couple of times like with the fronts but the full pedal doesn't seem to have come back like before. i used a tool to screw in the rear piston all the way just like the chilton manual says to do. i took it down the road and did 5 successive 60 to 5 mph stops with moderate braking and plan on letting it sit overnight to cure the pads. i know the rear brakes were working because the rotor was hot to touch. does it take longer for the rear caliper pistons to work back out to restore normal pedal feel. i had the brake fluid flushed before the upgrade with valvoline synthetic dot3-4 brake fluid. TIA
