Spoiler light getting no voltage
TrueBlue
Rocket Surgeon
Angola, NY
... LED's appear okay.
I believe it's fuse is #15 on the block... but that also controls licence plate lamps and I have those ON still.
Any inline fuses after the fuseblock? chilton's doesn't touch it (surprise surprise). Suggestions or experience?
projectSHO89
SHOless In St L
The High Mount Stop Light (HMSL) is in parallel with the corner stop lamps. verify if they work.
If none of them work, check fuse 1 in the I/P fuse panel. F15 does not supply this circuit.
Steve W
TrueBlue
Rocket Surgeon
Angola, NY
projectSHO89 said:
Plenty....
It's a lot easier when you have the drawings and service documentation in front of you.
Steve
I bet - is that on CD?
Bad wire in the last 1" between the plug and the LED, we drilled out the grommet, ran heavier gauge wire, soldered... bingo.
Thanks for the help, I'll remember you have the tech documentation. :D J/K!
