Speedo Problems-HELP!
kjw86ca
Tampa, FL
Hey,
I have a 1992 and recently put a new cluster in, now my speedo bounces about 5MPH in either direction when driving, and at about 70MPH, stops.
Also, my gas gauge is WAY off...it points at the fuel low light in the center of the cluster! And the temperature gauge is always below the cold line.
Please tell me what I can do to fix this.
-Kyle
rendyx
Buffalo, NY
kjw86ca:
Hey,
-Kyle
For the speedo, you may have to lub up the upper part of the cable. You'll have to remove the dash again to do this.
The gas gauge, I would check to make sure you connected it properly, but I'm not sure aside from that. Temp gauge might be a stuck t-stat even. Does it take longer than about 10 minutes to warm up (if the gauge works at all?)
kjw86ca
Tampa, FL
As the car warms up, the gas gauge keeps getting higher until it points at the low gas light, then stops.
The temperature gauge lays below the blue cold line, and then when the car is warm, it usually goes to about the cold line and stops.
Thanks for the reply, I really, really, really apprecaite it, and if you can get anymore info for me, that will be greatly, GREATLY apprecaited too!
-Kyle
