speed sensor gear
mccrash
ga
some how the the speed sensor gear thats in the transmission,the shaft broke right at the gear from pressure or heat.i been working on the car so long i dont know when it happen.The only place i know to get one is the junk yard.any one know any other place that might have them.
jmpSHO
Massachusetts
I had the same problem on mine well almost the same, but anyways I tried to get one from FORD and that it didn't happen but you might get luck with a local transmission shop. I wasn't so luck so I went to the JY and found one. Just make sure you use one from a SHO or there won't be the same amount of teeth on it.
shoon
cliTaurus
Dawson Creek, BC
If it's an MTX I can probably help you out. I have 2 spare transmissions laying around. Shoot me a PM if you are interested.
mccrash
ga
yeah thats it the gear that turns the speed sensor.mine broke off its shaft
