Specifications
pascofan92
Tampa/ St. Petersburg, FL
What is the required ATX fluid type?I used Mercon3.One more thing, What is the required battery amperage for a 3.2 ATX/my battery is corroding and it may be a little too big for the tray.Thanks
Alaric
hawkeye18
Sorta cares
Norfolk, VA
I know the stock size is a size 34 for the battery. I want to say 600 something CCAs? Personally I would get something over 700. Right now I have a red top with 800CCAs. Booyah. Dexron/Mercon III is the right fluid. ATF is the other kind, that's the WRONG kind.
The only way it's too big for the tray is if it really doesn't physically fit in there! Otherwise you're fine! :thumb:
93rev2sev
Hockeytown
My battery is slightly too big, also. Just make sure that it's secure. If not, you risk the alternator pully rubbing through the battery's case...that falls into the "bad things" catagory.
