speaker connect question
quarterboy25
Trenton, SC United States
I have a 93' ATX with JBL sound. When I unhooked the back speakers, i found four wires connecting to the speaker. I bought some aftermarket speakers and you all know that they come with only two wires: positive and negative. My question is which of the four wires are positive and which are negative and will i have any serious problems hooking them up. HELP ME. I am totally lost.
naval-avi8or
Chesapeake, VA
You can hook all four of them up. just as they are now. One set is ran up to the head unit for non-jbl/primium sound (output supplied by head unit) and the other set is run from the jbl/primium amp which connects in the trunk. So if your using an amp splice or get a connector to use at the trunk connector or if you have a powered head unit supplying power to speakers wire them to the connector at the radio.
Here is a sight that makes and sales all the connectors for the SHO.
http://www.scosche.com/scosche/connectors/ford-premium.asp
