GreenShoOwner
I was pulling modestly high RPMs (Opened the pipes, smiled...) coming off of a highway stop sign, ~55mph. ...The engine stuttered, the tach when ABSOLUTELY BEZERK, I kept it in gear, and came off the gas, and waited/prayed... ...And then the car was fine. I completed my run to work without any further indication of trouble. ...I worked for several hours, then headed to the company picnic. ...Again, no trouble starting, no trouble moving out of the parking lot. ...Then, when accelerating onto the highway, the tach once again went NUTS (spastic fluctuations all accross the tach, no pattern...) and it didn't pull out of it. ...I was able to run (very, very roughly ; lurching) enough to get it back into the parking lot.
...From what the mechanic told me... ...He ran a compression test, and it checked. ...And they cannot pull codes from the EEC. ...This would sound like a textbook EEC problem to me, but... ...Usually when a circuit goes, it's just gone... ...They don't come back when you drop RPMs, etc... I really suspect the Crank sensor, and now that I know where it is, I did look at it. ...It's <gasp> still there. ...And a bit oily. I can see the EEC through the (drawer-removed) glovebox, and it looks like an easy job. ...But I don't want to shell out $300+ for a part I don't need.
Worse, the symptoms could possibly be a hole in the piston/wall, but this is the reputable 3.0L Yamaha engine, and I kind of doubt it. ...And apparently it has passed a compression test...
What do you experts say? -- I appreciate the support.
