spark plugs
smccprez
ca
Hello, what's the best way to change the back 3 plugs?
Thank you
if you have an atx car, you can lay on top of the engine with the right socket wrench and get them out/in. It helps if you remove that little vacuum canister for the secondaries.
if you have a mtx car, you can do the above if you have little arms/hands. some guys need to r/r the intake to get to them.
Irish Pride
Irish Inside
MusicCityUSA
Im thinking the upper intake will have to come off
Nope. I can change all my plugs and wires inside 20 minutes. The intake does not have to be removed for either. You need to remove the hose connected to the back of the intake and you will need to move the vacuum canister and remove the bracket that holds the vacuum canister. After that all you need is a very long extension. Its that simple.
smccprez
ca
I'll get after it this weekend. Hopefully I don't have to take the intake off
