Noobz347
Gents,
I've been troubleshooting a heat soak/no start condition on my 95 and today, I either broke or discovered a broken spark plug wire connector end at the coil pack.
So take a look:
http://rcmautomotive.com/id10.html
I'm looking for a recommended wire set from you folks who have run them on these cars. I'm pretty partial to the set from Taylor because that's the brand I run on the Mustang and they're probably the best set of wires I've ever had.
What do you all run and what works best and which ones are the crap wires?
Thanks in Advance,
Noobz
Edit: Side Note: They look like a pain in the ass to route so should I replace the plugs at the same time? I've pulled the front three plugs and I don't see a thing wrong with them. They're platinum plugs. I can get a part number off of one if that matters.
Thanks.
So take a look:
Thanks in Advance,
Noobz
Thanks.
