SouthBend
92sho16
b00sted
Liverpool, NY
I bought a southbend rally clutch about a year ago and in early july had tranny problems. While i my transaxle was being rebuilt by Bruce M.(netviper) he informed me that i had a bent pp strap. At the time i needed the car to be put back together so Bruce helped me out and put a shonut pp that was supposed to go into his car into mine instead. Well after nowing all of that your ready for the actual feedback which is i had sent the pressure plate back and they replaced the strap with no questions asked and also resurfaced the pp, i was throughly impressed with this and even though at the time i was mad because i had to spend more money on another pp all is well now that my fathers car needs a pp. So the purpose of this thread is that even though i had a rare problem which was believed to be a factory defect southbend fixed it for no charge, well for the cost of sending it there was the only thing.
SHOguy 92
Duluth, MN
You sure your flywheel was resurfaced last time you had a clutch put in? Miltownsho's flywheel wasn't resurfaced when he bought his car with a new clutch, 7,000 miles later the clutch went, it had a bent strap......
But wheres the actual review on the clutch here? :confused:
MilTownSHO
Horicon, WI
My clutch starting slipping due to the Fidanza never being resurfaced. I broke the PP strap at the dragstrip when my halfshaft snapped.
He's saying he was impressed with Southbend because they fixed his stuff no questions asked! :thumb:
SHOguy 92
Duluth, MN
In the pic I seen I could've swore it was a bent strap :confused:
92sho16
b00sted
Liverpool, NY
I couldnt really give you a review of the clutch because im pretty sure that it either came bent or didnt take much time to bend so i dont know how the clutch should have really felt, when i put the southbend clutch in i had a brand new fidanza that i put in as well so it wasnt that the flywheel wasnt surfaced. I can say that shonut hd pp, sho nut ceramic tob, sb rally disk, and fidanza are a nice combo, stock feel and revs like a motorbike, my idle i would say you can notice is a little rough but i have intrax, tokicos, and al sfbs.
Bizzy
I didn't replace the insert on his fidanza as we put the Southhbend Raly disc back in there. Even if a non ground FW could bend a strap (i really don't see how) I highly doubt that one of SHOnut's HD pp's will ever bend a strap even with high RPM dumping downshifts.
FWIW I have always been told the only way a strap bendss like that is high mph downshifts without proper rev matching. :)
Very cool that they took care of it thhat way for you!!! Make me think I would buy from them, though then again I would think Josh@SHOnut would do similar.
MilTownSHO
Horicon, WI
I did bend a strap, but that had nothing to do with it slipping do the the flywheel never being resurfaced. :rolleyes:
