Sound proofing trunk??
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
Has any body ever sound proofed there trunk and the wing? Right now i got 2 12" kicker comp vr subs. And they are just rattling the **** out of my trunk. And what really is rattling the most is my wing. i was wondering what would be the best way to make that wing solid back there????
Thanks
ChrisR
Las Vegas, NV
I have soundproofed my trunk. It was a big improvement in the sound, and it stopped a lot of the rattles, but my spoiler also still rattles a good bit. I don't think you can do too much to stop the spoiler from rattling.
zyntax
nj
I know quite a few people that have soundproofed thier trunks due to insane audio systems. Dynamat works great, I've heard a before and after with it, and it does make a world of difference.
RI-SHO
B to the BANNED
Pawt., RI
For temp. thing try serveral sponges under the wing if that is the only thing rattling for now.
ShoGuy93
I was thinking maybe put some silcon sealent underneith my wing to seal it up. and then take the wing completly off...And then put some rubber washers on there to stop the rattling??? what do u think of that??
<small>[ September 02, 2002, 07:54 PM: Message edited by: ShoGuy93 ]</small>
underdog1924
Haverhill, MA
I highly suggest Raammat. I don't remember the guy's email but I think that if you do a search you will find it. Awesome stuff, just like Dynamat only much cheaper.
ShoGuy93
I just really need something to seal the wing.Or stop is from rattleing against the car. I may try the foam pads. then look into something else...
Aspect
Lowell, Michigan
SHOGuy93: Your on the right track. Sometimes you have to try different things out to see which one works. I haven't done my SHO's trunk, but I started my 97 Cavalier and had done some friends trunks. It takes time and $$$ but the results are well worth it.
mike a.........
miami ,fl
shoot DYNOMAT IS THE LEADER IN SOUNG PROOFING.. IT IS QUITE EXPENSIVE BUT MORE THAN WORTH IT BACAUSE OF THE FACT THAT YOU ARE LOOSING BASS... WHEN YOU HAVE SOUND PROOFING IT SORT OF SEALS YOUR TRUNK SO THAT AIR FROM THE BASS WILL HOT GET OUT .. AND AS YOU MAY KNOW IF YOUR TRUNK IS PRESSURIZED ALL AROUND EXEPT FOR THE SEATS THAT IS THE ONLY PLACE IT WILL GO ....WHICH WILL GIVE YOU A MUCH BETTTR SOUNG INSIDE........ shoot shoot
