Someone Help PLZ!!
J.P
Guelph
I got a 95 SHO ATX and i got this weird sound like when i drive over 40kms the car sounds fine but when i start to brake i hear something underneath the car that kinda sounds like theres water flowing and the back rear tire makes this WOOO sound like maybe it might be the brakes or soemthing cuz even when i release the brake and the car moves on its own it makes the exact same noise and i dunno what it could be, and it also sounds like the tire is rubbing against something ,its jus weird so please help me out.
thanks
j.p
Markus
Ottawa, Ontario, Canada
J.P:
thanks
j.p
Welcome to the forum. I don't really understand your problem. Perhaps you could rephrase it and be more specific? While you are at it, perhaps you can use better grammar. This will help us help you. thumb
You say you have problems when driving more than 40 kms. Is this speed and/or time dependent? Do the problems appear at this distance regardless of how long it takes you to travel the 40km?
<small>[ March 27, 2004, 07:55 PM: Message edited by: Markus ]</small>
Ishodu
You should remove the rear tires and take a look see if anything is loose or if the brakes are sticking, see if there is any play in the wheel before you remove it by pulling on the top and bottom and the sides. Just take a good look around see if you can find something out of place.
