SHObill
'The Collector'
vacuum leak.
As it begins to idle, the iab is able to keep up for a while, then it starts closing to lower the idle.
As it closes and the engine speed slows, the vac leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops...and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops... And the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops... And the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops and the iab responds by opening back up...as it opens...the engine speed increases and the vacuum leak begins...the iab responds by closing and as the engine speed slows down the vacuum leak stops
sound about right?
absolutely!
