SeanMc
NoMoSHO
Now I have a CEL after the computer was reset.
I checked the codes:
KOEO
122 = TPS voltage to low.
KOER
CEL immediately starts flashing 9 as if I just did the cylinder balance test. I cannot get into the KOER test mode. The RPMs are still staying up in the 1500 range as well. I played with the screw a bit, backed it out, and the throttle stays right where it is and feels stuck when you go to rev it. Isn't it supposed to move back with the screw?
Any suggestions?
Thanks.
P.S. I don't seem to be having the other issues like before. Car shifts better, and power seems to be back.
*edit* I cleaned the t-body out with some carb cleaner on a rag...no change.
KOEO
KOER
Any suggestions?
Thanks.
