Snapped a belt, don't drive at all?
EMB2580
Mike is a L O S E R
Zion, Il
My roomate took the car to work today aftere we have been letting it sit since it has bad motor mounts. I told him he could drive it so long as he takes it easy on the car. On his way home, the power steering/water pump belt snapped off and is now all shredded up. I knew it was pretty worn out when I got the car. Let me know what you guys think. Thanks.
38SHO
#1 Oil Abuser
North Palm Beach
without a water pump working things will get heat up rather quickly and not cool down....... if it was just P.S. pump then you could run without it...
just buy a new belt
EMB2580
Mike is a L O S E R
Zion, Il
I think I might have found the culprit... the tensioner is supposed to spin freely, right? because I can't get it to move at all.
TYSHO
Earth
Yes...
Yeah, tensioner pully bearing seized. Been there, done that....
Best bet is to find a used pulley either from a junkyard or from a member here. They are extraordinarily expensive from the dealer (if still available) and are not available aftermarket (regardless of what certain parts lookup sites say.)
EMB2580
Mike is a L O S E R
Zion, Il
Oops, nevermind then. Kinda like the front motor mount, huh?
