smoking on accelration
CheckerSHO
Ford Employee
Acworth, GA
hmm i took off from a light today WOT and had a friend behind me...he said after the secondary runners opened i started pouring blue smoke. I knew it was going thru some oil so its not a real big suprise but its going thru about a quart in a week and a half with periodic WOT's.
Is this typical of a SHO motor with 135k on it? i had a previous sho that had 125k and it did similar things...only burned even more oil. This sucks frown
Huntervf
Bored now
Back in Michigan ... again.
Every SHO I've ever seen smokes like that from WOT...that's what happens when the tires let loose :D
Seriously though, the oil consumption sounds high. How many miles are you putting on in that week & a half time frame? Also, what grade/brand oil are you using?
CheckerSHO
Ford Employee
Acworth, GA
hmm its going thru about a quart every 400 miles, with some city driving, some highway, some WOT. Im running castrol 10w30 right now, but im thinking about going to 10w40 to see if it helps any frown
snowwind1990
springtown, tx
Is it dripping while it's sitting?
Crank seal and rear main maybe...if you are burning that much oil, you probably need valve guides sealed up...oil in plug wells too?
eek!
ma ma m, houston, texas..........why don't you meet up with us and let us have a look, hmm? eek!
pete c
ellington, ct
Is it possible that when the secondaries open, any accumulated oil residue in those runners blows through? Does the smoke go away after a short period? Try an extended secondaries open run to see if it goes away.
SHOemup
Dalton, PA
I think blue smoke can also mean that your rings inside your motor are going bad. If this is that case, you might as well rebuild the motor while you're in there
You may want to remove the intake's crossover tube and inspect the interior of the plenums. You are looking for puddles of oil that are coming through the crankcase breathers. This oculd be due to over filling the crankcase with oil or running the car upside down. If no standing pools of oil, your blue smoke is coming from oil leaking through worn valve guides, worn rings or both. None of these cases would be normal for a SHO engine with "only" 135,000 miles.
Is that like a post-****** cigarette? (Sorry, I can't be serious all the time).
Scott
CheckerSHO
Ford Employee
Acworth, GA
snowwind1990:
eek!
I just had to move back to georgia actually :(
the SHO made it fine on the trip but it is going thru a lot of oil, and it is burning it not leaking it(no drips).
it didnt go thru any at all on the trip home(highway driving) but i did like 3 WOT runs once i got here and now its a quart low :(
guess its no more hard driving for me
hosbaldosho
