Sluggish 0-60, any suggestions?
jasong_10
Croghan, NY
"They" as in Aero Force or as in the aftermarket? I have seen the EPP pod for $300 but, I have not seen any others.
My apologies, I just checked the AeroForce site and they no longer list the dual pod I was referring to. Not sure what happened, it was there a couple months when I was considering going the boost gauge route myself . . .
csmith
NC
Take the engine cover off, a little behind the front furthest right spark plug is a little black box that will have 3 different small vacuum lines coming off it. One of those goes directly to the right and hooks onto the charge pipe. It is extremely common for those to get blown off because ford thought they did not need a clamp. Having that blow off will cause you to have no boost.
If you can't figure it out just post a picture of your engine bay in that area on here and someone can tell if that hose has blown off.
Mine blew off but the effects were different than this. Is it tuned or stock?
