Mike Spataro
My 92 has problems with the parking brake. The parking brake pedal needs to be pushed almost to the floor to hold the right wheel. The left side rear brake does'nt hold because the cable appears to be too long and cannot be properly adjusted. The left side cable casing should be seated in the frame of the car but it is about 2" away from the frame. If I push the casing in the grommet to try to seat it, there is too much slack in the front cable that is under the doors and entering to the pedal mechanism. Does this sound like a streched cable? Has anyone had this same situation?
It appears that the arms that are connected to the calipers are ok and the cables are free in the casing. Thanks for any information you can provide. I did'nt find any information in the search feature.
