JohnKay
Hi all,
Been a SHO guy since buying my first brand spanking "new" Titanium 89 Gen 1 - 220K and still runs. Since then I bought a 94 Gen 2 MTX back in 1999 - Runs great with 98K. However I've just started a new job that will take me 2.5 hrs drive through Washington DC traffic 1-2 week. Did the drive with my Gen 2 MTX a couple of times and aside from the increased wear and tear my freaking left knee will never be the same again.
So says I I'll find a better option....couldn't find an auto Gen 2 in really great shape so I have my eye on a 99 silver Gen 3 that's been owned from new with normal services every 3K. Older driver that had the 5 yr 75K ESP plan so anything through 75K was done like magic. The Cams have not been welded, the tranny shifts well but will need a flush, the tires are miserable - GY Eagle GSA's - front and will fit's on the rear...so these will need changing.
OK - Here's what's giving be doubts and I could use your thoughts : )
1 - Steering wheel spokes are off 2 inches to right...may just be in need of alignment since car doesn't pull.
2 - Front dash has 3/4 inch air space between it and the top of the instrument cluster....Ford Salesguy thinks this is from the sun over 10 years...maybe but could also be possible accident or other? Is this common...how to solve?
3 - Anti-reflection black cover on dash coming loose by the A pillars...is that normal?? edge looks like a wing flapping up and down on either side
4 - Front center console cover has been seperating from the padding and naughahyde...former owner tried to glue it back together...looks like X@#!@#.
Is this normal....Could hopefully pick up a replacement cover (grey).
5 - Seems to be a slight shade difference between the ground effects/front bumper vs the rest of the car - assume this is just sun fade difference between the painted plastic vs the painted sheet metal.
6 - Some minr surface rust passenger side rear wheel well....fixed 9 months back but bubbling again.
Anyhow the car has 113K on it and the Ford Oassis report incredibly showed 36 freaking pages of repairs (inlcuding LOF's) so it does appear that it has had everything it's needed to this point.
Your thoughts and suggestions are really appreciated. I am sure my wife will have my head in a basket if I put the 96 conti out to pasture and this turns out to be a money pit.
Thanks all,
Virago9577
Thanks all,
Virago9577
