Shredding Chrome Wheels
SHOWHAT9
WHEATON, IL
Heard a strange sound coming from the front passenger side today. Pulled off the wheel thinking maybe the pads are sticking, lo and behold, the inside of my rim's plating is literally shreddig off. Out comes the wire brush, peel off as much as I can and clean it up. Anybody else ever see this before?? Any clue as to a cure other than new rims?? :confused:
<small>[ April 12, 2003, 09:17 PM: Message edited by: SHOWHAT9 ]</small>
DavidT
TN
seeing how you are my fellow sho bro, I will bite the bullet and buy your "defective" chromes thumb
no, seriously :D
MilTownSHO
Horicon, WI
If your talking about the inside of the rim that you can't see unless you take off the tire, then yes I have the same problem. One of the rims is peeling badly and I wondered the same thing as you. shrug
<small>[ April 13, 2003, 12:21 AM: Message edited by: MilTownSHO ]</small>
wdnitro
Houston,TX
Mine have done the same thing. I just pull the big pieces off when they are not on.
rendyx
Buffalo, NY
Well, us basketweaver owners have had this problems for ages now! :D Basically, you live with it until it grows so bad you sand them down and paint them.
SHOntell
**** Rapids, MN US
Mine have been isht for a while (2 years). I have them on my gen I and some of the peel/buckling is starting ot show around the valve stems. They still look great, but I wish they werent that way. Oh well.
If it isn't one thing, it's another!
headbang
Mike
Bryan C. King
Norton, MA
Mine is doing the same thing, I am also having problems keeping air in some of my tires. I have tried everything and can't seem to find the leak. I was told that the chrome was probally peeling around the area where the bead is, but that is not true. I think it is time for new tires......
tyrantx
Vancouver, B.C.
A few questions and answers about chrome peeling I pulled off the net with a google search:
We are having sporatic problems with the chrome peeling off of aluminum auto wheels. I have been told that the brake dust from the disk brake pads can cause it if the dust is allowed to stay on the wheel for an extended period of time. Does this sound correct?
It is true that the cleaner a surface is kept the less prone it is to corrosion because there are fewer differential oxidation areas. And it is possible for certain foreign agents to accelerate corrosion, maybe even cause pitting.
But no, it doesn't sound correct. It sounds like a tall tale to assuage you. Peeling occurs because of inadequate adhesion, which translates to something improperly done at the plating shop.
Intermittent problems with plating peeling on Aluminium Alloy Wheels is most commonly traced to the following factors:
1 ) Poor attention being paid to the Zincating step (s ) prior to the initial "Strike" plate
2 ) Contamination of the "Strike" bath with Zinc from the Zincating Stage
3 ) Insufficient thickness in LCD areas of the wheel .
There are of course other causes but these are the major causes found in "aftermarket" wheels.
I have read that chrome plated wheels will over time form stress cracks related to the differences in thermal coefficient of expansion between the chrome and the metal that it is plated to and this can lead to peeling of the chrome and possibly tire pressure loss due to the cracks runing up under the tire bead.
Can someone give me insight to this problem?
The conclusion is correct, but the steps leading to it are not. Chromium plating has been used to solve thousands of challenging engineering problems on piston rings, aircraft landing gear, hot molding, jet engine internals, and on and on. So the theory that its coefficient of thermal expansion causes peeling to develop is complete nonsense.
But peeling does occur and can lead to the loss of bead; so if it does, tell the plater or wheel manufacturer that you want your money back because it wasn't plated properly and you're not going to listen to any pseudo-scientific lame excuses.
