Show Everyone how the SHO Gets Down
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
Our Livernois Motorsports spring kit lowers your SHO 1.4 inches in the front and 1.5 inches in the rear for a greatly improved aggressive look. Obviously, a lower ride height will help fight body roll, and improve overall handling. Progressive rate springs gives you a smooth tight ride with better braking and handling. Kit comes complete with front and rear springs and rear camber adjustment bolts.
80 h images ePIM original ZZ4 LPP303101 side right
  • SKU: LPP303101
  • Front Lowering: 1.4 in.
  • Rear Lowering: 1.5 in.
  • Superb Ride Quality
  • Reduce Body Roll for Handling
  • Enhance the look of your vehicle with a reduced fender well gap
SHOnUup4
SE MI
Ooh, pic of the camber bolts by chance?
Thanks
SHOForumSponsor
Sponsoring Vendor
SHOnUup4
SE MI
Thank you...and shucks
SHOForumSponsor
Sponsoring Vendor
Hello LMS,
Do these springs fit all years of the Gen 4?
What is the MSRP?
They do. (TYVM @Hebes10) I included a link in the original post as well.
  • SKU: LPP303101
onespdfrk
wtf...
Bloomington, IN
Sweet - this is the next item on the mod list!
Will you do the install if I come to your shop?
SHOForumSponsor
Sponsoring Vendor
These bolts are meant for our kit. I cannot assure you that they will work with your kit, but yes you can purchase them separately. They are $39.99.
zach_435
gilroy california
Does this bolt replace the upper contol arm bolt?
I am also curious what the max amount of camber that can be added with this is?
Maleckii
What's the ground clearance with these installed like? I'd love to get rid of that high stance, but I'm concerned about speed bumps and snow.
OmaHahn
Omaha
This is how it should've come straight from the factory! I have the PP option on my car so I don't notice any difference between stock and the lowering springs! The top picture is the most recent one after a Paint Correction and Ceramic Coat job - I can't describe the difference this made with the paint! I know one pic is inside and the other is outside, but even outside it's a huge difference!
Exotic Detail 4
20170617 113224
Yep....Ingot Silver is my favorite color.
Csbbrah
Ky
Exotic Detail 4
20170617 113224
Wish they had that color or the red in my area on a pp when i was buying. Beautiful car man.
Sent from my LM-Q610(FGN) using Tapatalk
