Should I get a OCC or AOS
SHOHARD
So I was checking a while back why my boost was low and found a hole in my BOV. I am still waiting to get my pipes. But there was oil in the pipes and from past experiences it was because I did not have a oil catch can or seals were bad. I am not seeing oil around the turbo and there is no leak. But I want to make sure getting a OCC or AOS is worth it.
What do you all think? What is the best route? Any info will be great!
Also has anyone else had a problem with oil in there hot pipes?
Thanks!
Coasttime
Ahrmadillo
Wisconsin
SHOinVa
Tidewater Va
There are a ton of posts on this subject and the only consensuses is that cars with a meth clean themselves and don't need a catch can. No one will even agree which catch can is best for the SHO setup. I have even seen where some people believed the catch can caused damage to the engine. So IDK what to tell you, I am going to purchase the one above at some point just to be safe. Its cheaper then the others, easy to install and does not require you to tap into the turbo for suction. Look around and read then decided for yourself. Have a great day.
Charlie
