SHOsource Articulating bearings
mosho93
Well-Known Member
Wausau, WI
Do I need to grease these when I install them to prevent any sweet noises?
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Maybe thats that damn noise I keep hearing.... ? I cant seem to find a thing else loose.. unless a front strut cup reciever is loose and starting to give and I cant see it.
Would those work with the "other" adjustable mounts?
mosho93
Well-Known Member
Wausau, WI
I will be running them with Ingalls for the time being until I can get a set of SHOsource camber/caster plates. There are/were other guys running them on Ingalls as well.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
hmm, guess i have not ran mine enough, as they were quiet for me. SHOsource site says they are self lubricating. I would try and use something dry, so as not to attract dirt, which could have a very negative effect on the operation of the mount. Is anyone using these with the ss camber plates?
SHOspazz92
Banned
Triad Area, North Carolina.
I'm using these with the SHOsource CC plates. Another problem I have with these mounts is that they "Stick". For some reason, If I make a sharp right or left hand turn (From a stop at a street corner, or out of a driveway) the steering would actually drift off in to that direction (whichever way you just turned) as if the alignment was off. It's like they were binding up. That's another reason they need to be greased.
Small price to pay for having a halfway decent suspension setup. It still drives me nuts sometimes tho.
-Sam
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
The articulating spring mounts were designed with self lubricating plastic. If you do want to go the extra step and grease them, that is ok. You should use silicone grease (dielectric grease works great). The grease will tend to attract grit and dirt, so it would pay to check and clean these periodically if you do grease them.
Hope that helps
Mike
SHOspazz92
Banned
Hope that helps
Mike
They may be self lubricated, but for how long? Mine will start to pop and even get hung up if I don't grease them every few months. I'm not trying to knock the product as its a good one, I'm just giving you some honest feedback.
-Sam
Ishodu
I used silicon spray and only had to do it once last year. They were making noise as soon as I installed them.
mosho93
Well-Known Member
Wausau, WI
Update:
I have had mine in for 300-400 miles now. As soon as I installed them, I could instantly hear binding noises when backing out of my driveway, pulling away from a parking spot/stop, etc. I can't stand random noises because then I think there's something wrong with my suspension. So I stopped Advance Auto and picked up a can of dry graphite spray lubricant for around $5. The nice part about this is you don't have to take the wheels off, just need to jack it up and use one hand to pull the "self lubricated" part of the bearing apart from the stationary part and spray some of the graphite on it. It drys instantly and doesn't absorb rocks, pebbles, and other junk. After 400 miles, the binding noises haven't come back, yet. I will update again when I change my oil in a few hundred miles.
