SHO Tailight Chrome Trim peeling help.
Sonnyburnett84
I just bought a 2012 V6 turbo charged SHO with 42,000 miles. Unfortunately when I bought it the chrome trim around taillights were peeled and yellowed, not pretty. Ford said its a defect asked body shops if its fixable with scuffing and chrome paint. Apparently not a good idea at all. New taillights from ford installed are 1,000 and would think the same thing would happen. Perhaps after market taillights with the hope that the company/manufacturer uses a deferent chrome. Any help/insight on fixing or replacing would be a huge help.
Thanks!
MIKE
SEL taillights will eliminate the chrome entirely. look around eBay or junkyards for cheapest pricing.
And yes you can sand down the fake chrome and paint over if you so wish. or simply plastidip.
BlueSHO
Yes get the SEL tails the 12 SHO's are junk. I had 2 sets replaced under warranty in the 3 years I had my 12. The lying dealer said anything from it's not a problem that Ford knows about to I was using soap that was too strong when I washed the car
Sent from my DROID RAZR HD using Tapatalk
Sonnyburnett84
Thanks! So a 2012 SEL taillight set will match perfectly and free of that defect? Id rather just sand and paint but 4 body shops said it won't work doing that...
Usmcsho01
Multiple people here have sanded and painted you need to use a particular adhesion permoter (made by 3m I believe) after sanding down the chrome. You could always wrap in vinyl too
Sent from my XT1650 using Tapatalk
Sonnyburnett84
If theres a possibility of SELS doing there same thing would aftermarket make more sense both money wise and not having same peeling defect? Thanks again.
Sonnyburnett84
Ok great..thanks ..id much rather not have to do replacement lights. Ill look for sander adhesion. Any insight on sandpaper grit and best chrome spray for color and longevity?
sticks1680
Sel lights have no chrome. Take taul lights off. Use a dremel tool to sand off chrome.
Sent from my SM-G900P using Tapatalk
Sonnyburnett84
ok thinking sanding off chrome, applying primer of sorts, then just paint black..I assume that would look better than paining chrome..whats the best/strongest spray.....plasti drip?
Thanks!
907SHO
Alaska
I used a pressure washer to peel mine off completely and am going to paint it black
Sent from my SAMSUNG-SM-G935A using Tapatalk
moonie
NC
Ford replaced the ones on my 2011 once as it was under 36K, peeled again, didn't worry about it after, sold it when I got my 2016, thankfully it doesn't have the horrible chrome.
