We are in the home stretch and ready to build the prototype. We are also at a major decision point and ask for your input. We have two ways to build this kit, but probably only enough market to support one version.
Option 1) Build the kit to keep the cost down. This does not mean cutting corners, but it does mean no frills. We would use a common turbo to keep the cost lower. As in most setups, you would have to tap into your oil system for lubrication and also install a drain tube into the pan. For reference, this is the same way all the Vortech superchargers from SHO Shop were lubricated. The system works fine, but it does scavange some of your oil pressure and flow that would otherwise go to the engine. Low risk based on the supercharged history, but still a negative of this system.
Option 2) Build the kit with a high end sealed turbo. We found an excellent turbo unit that does not require an oil line or drainback. I was skeptical at first, but after a lot of research, I think this is truely the better option. The main benefit is you do not rob oil from the engine. A secondary benefit is it is cleaner and much easier to install (no oil drain to the pan). The downside is this option would probably raise the cost about $1000 in round numbers.
So ... do you want to keep the cost down or do you want the benefits (and costs) of the new technology?
Mike
Mike
:wave:
