sho skipping
gabriel elmore
columbia s.c.
i had a mechanic put a clutch in my 92 sho mtx
i realized it was running rough. after looking the car over i realized that the plug going into my dis module that is closest to the firewall had been severed and a piece of the dis module broken off i found a sho in the salvage yard and took the plug and install it on mine but the car still skips it's just constantly back fires at idle a ford mechanic said the dis module will not make it skip like that i need help everybody is scared to work on it and they all call it junk
pjtoledo
'ol man in the SHO
toledo,ohio,usa
How did it run BEFORE the clutch work was done? The DIS module needs a heat sink grease applied sparingly to the mating surface. The DIS also needs a good ground to the intake, remove the screws and clean them and anything they touch. Also loosen, then re tighten the bolts securing the cross-over tube, the ground goes thru them. If you have access to a timing light, verify the timing.
Perry Toledo,Ohio
ocso650
