bobreimer
I have an 89 SHO with a 9lb supercharger kit from the SHO Shop. Put the car on a dyno the other day and it builds power smoothly to about 280 hp at 5,800 rpm.
After that the power drops sharply. By 6,700 rpm it makes 138 hp. The belt is not slipping. The boost builds smoothly to 8.5 lbs at 6,700 rpm ..... but .... the air fuel ratio starts to go lean at 5,900 rpm and gets steadily worse as the boost increases after that.
The engine seems fuel starved. I have a new 250 lph fuel pump and 47 lb injectors. I suspect the fuel pressure is dropping off and I need to get a gauge on it to confirm this. I'm wondering if the original fuel pressure regulator isn't maintaining pressure?
Has any one else with a blown SHO had a similar problem?
Bob
Bob
