SHO questions
SHOman247
michigan
Anyone know how are si it to replace the rear main seal on these engine and also is there a way to fix a leak in the plastic coolent tank?...thanks
Rear main requires a tranny drop. Are you sure it's the rear main seal? It could be a few things, most notably the oil pan seal.
I know how hard it is (is that what you were asking?) to replace a rear main seal and yes, there is a way to fix a leak in the plastic coolant tank.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
sdpatt:
thumb
SHOman247
michigan
buying this 90 sho off this guy and he says she's leakin oil from the rear main seal area but might be the pan..he just put in a new clutch...so how often do they go bad? I think it's either misaligned or been damaged after he put the tranny back in..how would i fix it..is a rear main seal expensive? also bout the plastic tank how can i fix it? is the some time of plastic cement or eppoxy i could use? Thanks
