Sho puttering below 3krpm and when load is put on engine.
ShoThang
Omaha
Hi guys/gals.
I havent been on in a while. What's new in the SHO community?
Ok here's the dilly:
I had my stereo installed last week(I'm sure this has nothing to do with the problem, but I thought I'd share just for the **** of it) and as I was driving home afterwards, my car started puttering when I hit the gas harder.
I got home and reved my engine and it would putter untill about 3k rpm and then it would sound fine. When I'm driving and I'm only at 1/4 throttle, it seems to be ok, but as soon as I get on the gas a little more, it would start shaking and puttering untill about 3k or so and then actually start accellerating (but still not as strong as normal). shrug
Now I'm a total newbie when it comes to mechanics, but I am trying.
So far here is what Jeremy(94gSHO is what his name is on here I think) and I have tried:
- Checked Codes = None
- Cylinder Balance Test = Ok
- Injector Cleaner = Nope
- Cleaned MAF, and then tried switching MAF's because I thought I may have fried mine = Nope
- Checked Wires = Ok(I couldnt reach one of them in the back, but everything sounds fine in higher RPMs so I dont think it is that).
So far that is all I/we have tried.
Anybody have any suggestions on what I should be doing ??
Thank you for your time and any help/suggestions you may have.
JoeHoe_SHO
SHOPUKE
Rochester NY
Alternator or battery maybe...have not a clue but that could be...I think..More power drawn...when power used...I dunno, 4:35 in the damn morning, almost time to go home :D beer time
JoeHoe_SHO
SHOPUKE
Rochester NY
...Lashing out the action, returning the reaction
We go rip the torn away... Hippnotising power, crushing all that cower BATTERY is here to stay...
...Smashing threw the bounderies, lunacy has found me, cannot stop the battery!!!
One more time....
If you are having an engine misfire without a CHECK ENGNIE light, the cause is usually in the secondary ignition system: plug or wires.
Check the plug wells for oil or water. Check the plugs for correctness, correct gap and evidence of arc tracking down the insulator. Check the wires for correctness and age. If they are over about 6 years or 120,000 miles old, they are overdue for retirement.
HopefulSHO
Bellevue, NE
I'm HopefulSHO on here :) The wires look brand-new..not sure about the plugs though. Suppose we could take a look at thoes.
