SHO Phoenix Project
SHOyork
Bethpage, NY
I was fortunate enough to copy information from the SHO Phoenix Project webpage. I have most files in .pdf form, so I don't really know how i'm going to post them on here. If you message me with your email, then I will try and send you the files when I have free time. If you don't know what the phoenix project was, it was a guide(with photos) on how to perform most maintenance on the SHO.
Word Documents:
60K Parts List
SHO Replacement Parts Intervals
Suspension Guide
.pdf Documents:
Aluminum Subframe Bushings
Ball Joint
Block Warmer
CID Sensor
Clutch Replacement
CV Joint Replacement
Front 60K Guide
Upper 60K Guide
Front Brake Guide
Front Motor Mount
Fuel Pump Access Door
Gen II Center Console
Heater Core
Rear Swaybar Bushings
Rod Bearing
Tie Rod End
Transmission Disassembly
Trouble Codes
Valve Stem Seals
All the .pdf's have the photos from the phoenix project webpage and I tried to organize them the same way. I don't know if anyone transferred that page to anywhere else, but I couldn't find anything. I copied everything when it was obvious that the page was on its way out.
zak
east of Hartford
Anyone else have this info archived? The link above no longer seems to work.
David Carpenter
