Car gets a little unstable on some rough roads while hitting the brakes
slvr98camaro
Pittsburgh
This is on a 2019 sho non pp with 80k miles.
When I'm on roads with bumps and hitting the brakes the car feels very unstable, the steering wheel will almost **** out of my hands.
Issue started a few months ago, and i don't remember if I had my snow tires on or not when it started.
Suspension feels fine bouncing the car, there's no play in the wheels, tie rods and ball joints seem ok, by doing a visual and checking for play while driving and checking with the wheels in the air.
I'm not saying that there's no issues with the suspension because obviously there is, but i can't figure out what to look at next. The tires are needing to be replaced soon, they have 3-4/32 on the good tread, and they do look like they are worn down around the edges (most likely from going around corners, and not tire pressure) alignment gets checked 2x a year and is always almost within spec (within .1 of everything) i have no issues replacing the tires, but i think the problem started before I removed the snow tires.
Any ideas?
Mahu24
Prince George, BC, Canada
Did you check your struts? If they are blown out you're just running on springs, which is bouncy. Check/replace sway bar end links, they're known to go bad. I replaced mine with TTX links, they are MUCH heavier duty than OEM
slvr98camaro
Pittsburgh
Struts seem fine with the bounce test, the car doesn't bounce on bumps or anything.
I checked the front end links and they seemed tight with no play, but the smaller rear ones seemed a little loose, i could move them back and forth with my hand but the joints weren't popping in and out.
I took a good look at the tires and they are wearing very poorly. I'm wondering if the alignment is out, and that's what's causing it. The car was aligned around the time I got the snow tires. The alignment shop was having issues getting a bolt loose and I had to take it back for them to try again. I'm wondering if they did something there, and that's what's been causing the issue.
tires wearing poorly never good.
would agree on looking deeper into what the shop did to get better alignment. may have to take it to a different shop first, then to the shop that did the alignment.
how does the car track on level ground?
i would suspect control arm/inner tie rod/tie rod end. many steering issues arise there also.
Mahu24
Absolutely if the tires are wearing bad there's and alignment issue or control arm bushings are shot
slvr98camaro
Pittsburgh
The car tracks great on level ground. Highway driving feels great, then sometimes it will just feel a little sketchy out of the blue, it must depend on the actual road.
I was hearing a little noise from the brakes and i took them apart and found that the bottom slider on the front was very tight because the rubber bushing swelled and was hanging up a bit. I got that all fixed.
Not sure how much that may have contributed to it, but the pads were worn very evenly and there was no evidence that it was actually hanging up.
Mahu24
Check control arm bushings, that can give inconsistent issues
check the tires and tire reviews for tendency to wander. there was one tire brand i had aeons ago that wandered on bumpy roads.
