Aqua Roach
Deadly Insane
Hi, I've got a rather peculiar problem with my 3.2 ATX. Recently with the cold, 20-30 here in SC, my SHO doesnt want to start. It will crank, run for a second, than die. For that brief second it sounds like a normal run. It will do this even when I give it gas, no matter what it dies.
With that being said after around 4 or 5 failed startups, it will run for its normal second than the rpms drop to a near stall level, lopping pretty bad then stalling, at this point I can give it gas to maintain an idle, but if I let off it will most likely die.
If I maintain an idle for awhile and it gets to near-operaring tempeture, the car runs normal, perfectly fine with no rough idle.
It's pretty strange, it's almost all new everything on this motor, and all summer long I've had no issues like this. I couldn't find any vacuum leaks, and being how it stalls if I give it gas in the begining when it's cold I don't think its the IAC. Not to sure bout this one, any advice is appreciated!
