yes, either one of those can cause a misfire. Make sure your maf sensor is connected. If it is, make sure its clean. If not, clean it up real good with electronics cleaner. If that doesn't work, your MAF sensor may be shot.mechsho said:I have a misfire in my 92 mtx and cant fix it.I pulled the codes KOER 172 ego not switching lean bank 1,and 159 mass air flow voltage out of range.Wil this cause a misfire?
