go-pile-68
OK, I must confess. I own an 89 with 330k miles. I am good about some things and bad about others. This car is my daily driver. Here goes, I have never changed the brake fluid, never changed the power steering fluid, the A/C does not work and the ac clutch can, at times, be very noisey, never changed the coolant, as it leaks I just add more, I have gone 140k before changing the timing belt, and just as long before checking the valves and spark plugs. The accessary belts are at least 10 years old. I change my oil at 10k. My tranny fluid was changed at the last clutch about 60k ago,..................whew I feel much better. " This house is clean ". Done. Please be gental.
OH SNAP!!!!!
I'm not sure you should change any of those fluids now. It may not run the same or worse, never run again.
