My car has the symptoms of bad timing, due to probably jumped teeth, loosed tension, etc.
Car was running fine, jumped on it in third gear and pulled up to like 5k rpms, and it started loosing power. Go back to fourth gear, fine again. Go back to third and up to 5-6k again, same power loss. So, put in fifth and started thinking maybe oil in the plugs again or something. A few minutes go by and the power loss appeared at lower rpms, and some occational bucking/sputtering. Then I barely could accelate below 4k rpms. So I downshifted so I could pull in the gas station. Couldn't get it started at all. Towed her home with my buddy's truck at 3 in the morning. cry
So today I changed the fuel filter. No change. SLOSHO pushed my car up to 25 or so, I popped it, and got it running. Floored, going 15 mph in first. Drove it around trying to see if it would clear up. After about 3 minutes
, it finally rose up in rpm to near 4k. Seconadaries opened, and the car broke loose like a ***** ape. Full power from 4-6k and then power loss again. SO I pull it in the driveway. It has sat there for a couple hours and I looked under it, and there's a little puddle of greenish/brownish gooey liquid near the back of the motor (more brown than green - with no odor). So I'm puzzled about the leak, but do my other symtoms sound like a skipped tooth or loose tension of the timing belt? Motor just turned 160k last week. No 60k's done to my knowledge. Could be the original timing belt for all I know. I'm gonna start pulling the belts and stuff in a little bit and pull the timing cover off. Any ideas? TIA
<small>[ July 09, 2003, 10:28 PM: Message edited by: DJ SHO ]</small>
