I see SHO designated valve shims are labeled with a 4 digit number, but 29mm shims from bikes have a 3 digit number. Is it ok to use 29mm bike shims in my car? How do I convert the numbers?
Generally, the three digit numbers leave off the "0" at the end, IIRC. If they fit the bucket correctly, you can use them.
