Shift *** thread question
nik97
Mile high
Does anyone know if MTX shifter threads are the same as any year mustang shifter? Pics of different shift knobs on MTX shifters, anyone?
awb85
school in Boston
I don't have a picture, but I installed an aluminum **** on mine — the threads were too large, so I installed an allen head screw (with the help of a drill press) to lock it onto the shaft.
Havn't had any problems with it coming loose ever since cranking it on there — granted, I may have flattened some of the threads on the shifter rod.....
It's_SHO_Simple
Woodlyn, Pennsylvania
I have an all aluminum shifter from mustang and it fits just right. It's a UPR shift ****. I'm pretty sure any shift **** from a 87-06 mustang should fit on a MTX. Mines fits but it is a little short and sits higher than the the MTX ****. Hope this helps you.
They're very close. I had a round Mustang aftermarket Steeda shift **** on my GenI. If it needs to fit exactly to keep the **** facing one direction or to line up the shift gate pattern I'm sure you could monkey with the threads just a bit to line it up.
97SHOgt
Cincinnati, OH
I have the shift **** off a Bullitt Mustang it fits except I can't get the shift pattern to face the right direction. Looks sweet though with my black interior.
There are some reproductions that look oem but have a tightening allen head screw. You could modify yours like awb85 posted. Might be worth the effort to have it sit correctly.
91 SHO PLUS
COLUMBUS, OHIO, USA
I had a Bullitt Mustang shift **** on my old '90 SHO, and was able to get the shift pattern corrected by using a couple of lock washers on the threads under the ****! It does look sweet with the black interior, no doubt!:evilgrin: You'll have to do some experimenting to get it right, but it will work!:thumb:
Jeff
Black Stallion
Lehighton, Pennsylvania
Im sporting the contour shift ****. Its not a great pic but you can see it.
The bottom of the **** doesnt meet with the boot, but I like it like that. Man I need a new boot.
blacklabel
Hartford, WI
CerberuS said:
Someone here did install a 05-06 stang one , looks freaking awesome. I wonder if its a bolt on tho.
Are there pictures of that on a SHO anywhere? I might go with it. Either that or do what nik97 is going to get and possibly get a '99 cobra shift ****.
97SHOgt
Cincinnati, OH
Jeff
I'll have to give this a shot. Thanks!
jelloslug
Digital
Greenville, SC
I have a leather 00-05 Mustang shifter **** in my '90. On the stock shifter I had to cut down the threaded part about 1/4" to get it to screw down all the way.
93rev2sev
Hockeytown
If the leather on your SHO **** is AFU...use one of your old ladies retired black leather purses and stich up a new cover...I've done this twice and it seems to get easier each time. Results are VERY acceptable.
SHO92
Upper Freehold, NJ
I also have a Contour/Focus **** that I use sometimes.
Usually I switch between stock and a **** I got out of an 80something VW. The VW **** is plastic, but I love the shape of it. It's a rounded ice cream cone shape(best way I can describe it).
