SHOtimer
#2910
How much can the SHO heads be planed or shaved. I know they can't be shaved much, but I can't seem to find a specific amount.
Thanx, Doug
Thanx, Doug
Your going to have timing issues. You are running a DOHC motor. You just changed the distance between the crank and the heads. This will upset the timing.strings1732 said:I had my 3.0 heads shaved .005 when I installed them on my new 3.2 block. It was just to get them resurfaced from a possible warping issue. They ended up not being warped but they were heavily pitted from the stock headgasket, so I had them shaved anyway. Not a single problem and the motor has been turned without a timing belt on it so it's still not an interference motor.
Ishodu said:Your going to have timing issues. You are running a DOHC motor. You just changed the distance between the crank and the heads. This will upset the timing.
