JonVH
I recently posted about my SFBs but only got a few replys about the recall. I wanted to follow up based on my findings.
Symptoms:
A big clunk sound from the front end (drivers side?)under initial acceleration & on hard braking. I assume this is the sub frame bushings gone bad. More recently my steering wheel shakes at speeds over 20 mph.
My findings:
I found posts by Steve on testing SFBs & Motor mounts.
Sadly or gladly I did not fail any of the tests!
Motor raised up level in forward & reverse, no shinny spot on the manifold. Also the motor doesn't seem to move at all on the side to side wheel turning test as well as no subframe drop at all on either side for the lift the body test. SF bolts are in place & no wear around bushings.
Seems like it should be the SFBs but I can't see why or how. Any other things to look at?
Jon
Symptoms:
My findings:
Jon
