philw349
PhilW
My SHO has been pretty much out for the count for about a month. I haven't been able to fix what is ailing it. I replaced the fuel pump for a 190lph model. Then when that didn't fix it, I went back into the tank and threw out the pulse dampener and replaced it with the hose that came with the pump, as well as replaced the duck beak valve (was waiting for the part). Still didn't work.
I can get it to start by flooring it until it reaches a stable rpm. It seems to build up rpms like a locomotive. It has no liveliness at all until it hits 4000rpm, but it's a struggle to get there in neutral. When I let off it idles alright (which is an improvement), but then I just have to tap the gas pedal after that, and it immediately dies out. It's strange. The presence of fuel pressure seems to indicate the fuel pump is working alright. It hits about 42 psi primed, and then dies down to about 35 in 10 seconds or so. I couldn't run tests with it running because the crappy autozone pressure gauge broke (after 3 uses).
I took it to Pep boys out of desperation. They told me that everything they could measure was in spec, including the fuel pressure. Although I couldn't get ahold of the guy who did the actual measurements. Then they referred me to the dealership. I'm just wondering what else it could be. But then that could be a lot I suppose. Last time I took codes there were none. Maybe there will be some now in the more deteriorated state. The last thing the tech told me was to get the exhaust checked to see if its blocked, so I've come in a complete circle.
I'm all for paying the dealership for a diagnostic and then fixing stuff myself. That's pretty much my next step unless someone has better ideas. It's just frustrating dropping the tank twice and then having to get it towed. The joys of SHO ownership.
I must say I love the new site though!
