several questions about mtx
Michael R. Rudel
Pinckney, MI
i have a couple questions about driving an MTX.
first off, is it really bad to do under 50 (i.e. under 2000 rpm) in 5th gear? Someone said that is severley lugging the engine, even if there's not much load, but it really doesn't feel like it
second off, is it really bad to coast with the transmission in neutral, since it's synchro'd? i've been making a habit of this and would like to know if i should stop.
third off, is there a specific RPM that the power of the yamahammer peaks at? i usually shift just below red line when i'm trying to accelerate fsat, but is there any advantage to shifting sooner?
Actually, that was three questions. :)
1) You should not make a habit out of using heavy throttle with the engine under about 2,000 rpm. Yes, that would be considered lugging and it heavily loads the engine's bearings that do not benefit from the higher lubrication pressures and protection at greater rotational speeds. You can hold a steady state cruise and use mild throttle at these engine speeds to the benefit of fuel economy and engine longevity, but downshift if you need greater rates of acceleration. Remember that the automatic transaxle will downshift automatically to achieve the requested high rate of acceleration and to protect the engine.
2) Coasting with the transaxle in neutral is a concern only if you need to quickly accelerate to avoid an accident. I routinely slide the shifter into neutral without depressing the clutch when slowing for a stop. This shifter motion occurs without friction at about 1200-1300 rpm while the car is still rolling due to the IAC valve maintaining a high idle while the car is in motion. I do not depress the clutch again until I am ready to engage first gear to start rolling. This practice saves one clutch press and the resulting pressure plate and throwout bearing wear for each stop.
3) The SHO engine develops peak horsepower in stock form at 6,200 rpm according to the Ford literature that I have. This engein speed would correspond to the maximum rate at which the engine can do work. The measure of work is a combination of the torque produced and the rate at which it is generated. Torque moves the car, but horsepower is the rate at which the car gets moved. (A locked rotor is when the peak torque output of an electric motor is generated, but no work is being done since work is defined as force being applied over a distance. One horsepower is the work performed by lifting 550 pounds a distance of one foot in one second.)
Since the power (and torque) curves drop off rather quickly after the power peak for a stock SHO engine, you would like to keep the engine speed around that power peak as much as possible to achieve the quickest rate of acceleration. Shifting near redline is a good method of achieving the best acceleration since the revs drop well below the power peak after each shift.
Looking at the dynomometer curves that my engine generated last February (at 255,000 miles), it reveals that the modifications to my engine have kept the power peak near 6,200 rpm, but the power decrease above that figure has been greatly lessened by the intake and (primarily) exhaust modifications. My old engine was still generating 175 hp at the front wheels at the 7,300 rpm rev limiter. This change gives my engine more working room under the power peak and will allow me to benefit from shifting at the rev limiter.
(I needed a few moments of break from C++)
<small>[ November 13, 2002, 05:18 PM: Message edited by: sdpatt ]</small>
Michael R. Rudel
Pinckney, MI
Thanks for your help again, Scott. :) I was concerned about false information I had received that coasting in neutral was bad for the synchros. As for the heavy throttle use, yeah, I never give it much gas in 5th at all, even at ~80+ mph on the freeway I'll drop it in 4th to accelerate quickly, but it's good to know I can cruise at 35-40 in 5th to get better mileage and not damage the engine.
enjoy the break from C++, i'm using this as an excuse to get a break from massive PHP work, warehouse packaging, unix admin, and pbx programming (i'm the all-around-expert guy for a small startup)
~mrr~
Blast7
Rochester, NY
I never knew that just cruising at that low of an RPM would be okay as long as you don't use too much throttle. I guess you learn something new everyday.
DavidT
TN
very informative thread thumbs_u
Thanks!
Denny
Taurus Homeland
Atlanta, GA
Dave, I totally agree with your sig! thumbs_u
On a serious note, why do manual trannies have that distinct "WHIRRRRR" in reverse? :confused:
Chrisssssssss
vancouver, BC, canada
I believe the "whrrrrr" from a manual tranny is due to the forward gears meet each other at an angle thus reducing the gear noise. Reverse is more just straight on. I heard this from someone, and it makes sence to me, but please someone correct me if I am wrong.
drivinhard
Gainesville, GA
Basically yes. The forward gears are helical (quiet) while reverse is straight cut, cheaper to make (but noisy).
91WhiteSHOpa
PA, Usa
Alright! I learned two things! Heh! great post!
I personally wouldn't feel comfortable runing under about 1.8k rpm unless just coasting to a stop then it still feels like my car really doesn't like it. I don't know the techs behind it, but I don't think it'd be wise to lug it out to save a few bucks every couple weeks...
My opinion, take or leave it... burn_out
