Hello everyone, I have to replace my belts on my 95 SHO MTX. Can you all give me advice on changing the smaller of the 2 belts. The one that is drives the ps and water pump.
Its in a really tight location. I've never replace them, I had a shop do it when they replaced the timing belt years ago.
Instructions says to loosen the pulley nut and then back out the belt adjuster nut, and remove the belt.
I will spray the fasteners with WD-40 to help me loosen the nut and bolt.
Any advice and tips will be appreciated, the belt on the passenger side of the engine will tough.
Thank you,
Dkal
Thank you,
Dkal
