Serious Stalling Problem Need Help
RBINPHOENIX
phoenix,az
I have a 94 3.2L sho and after driving about 15 minutes it stalls.I've taken it to 2 different shops and replaced the crank sensor,coil,co2 sensor,computer,tranny shift sensor,alternater, and the ignition control module and the car still stalls.First I start to lose my tach and the check engine light comes on then it stalls.nobody seems to know whats wrong.That's why I need help.
wood_e
The dude
Ames, IA
Your water pump is probably leaking onto your crank sensor causing it to stall.
SHO#7
Cincinnati
You may get better response in the Gen 1 and 2 forum, but how about the cam sensor. I know that I left mine unplugged one time and lost the tach right before it stalled. In either case, good luck.
