What is the sensor that is tapped into the oil pan? I took it off a while ago and can't remember what it was I removed!
dantheman68 said:try some gasket maker or RTV sealant... but be sure not to use too much so you dont contaminate your oil
are you sure its leaking that bad? how bad is the smoke... you might want to look at your valve cover gaskets...
