i keep getting a cel for secondary air injection failure, i test the pump and it works fine?? any sugestions, im thinking it intermitingly goes out>>??
How are you testing it? Is it actually pumping air to the manifolds? The fitting in front is pretty easy to open. Could also be a diverter valve problem too. This could be a vacuum hose or bad vacuum solenoid.
It is usually the SSR that goes bad but if you can get it to run then that isn't the problem. What's the code?
