philjw90SHO
I have a 92 MTX with 107k and we just got finished with the valve adjustment and intake manifold cleaning. I have two questions. First is that my front secondaries are staying CLOSED at all times.
When I shut the car off the stay closed, and with the car running the stay closed, and above 4000 rpms, they stay closed.
Wierd thing is the rear secondaries work perfectly. I checked the electrical connection at the back and its plugged in. When I disconnected vacuum hoses, I only disconnected them at secondary acuators. Then I plugged them back in when I was done. Nothing looks out of the ordinary. No pinched hoses. Could the hoses where the T is be backwards, Meaning that the front on the rear and the rear on the front. Does it matter. I don't know. Any suggestions.
Also, after the valve adjustment. (We replaced all but 4 valve shims with brand new shims) There is a noise coming from the valve cover area. It is a constant tapping noise, not loud but it didn't do it before. There should be oil back there. Any thoughts.
one more thing. I accidently stripped a little bit of paint off the rear intake plenum. How can I touch it up. Is there a name for the color of paint on the manifold. Can I buy it. Where can I buy it. Thanks
Any help would be appreciated.
Thanks
<small>[ December 15, 2002, 01:55 AM: Message edited by: philjw90SHO ]</small>
Thanks
