SAI delete anyone?
TheSHO98
Vancouver Island
Alright so I have a P0411 code that likes to come on, has anyone around here have experience deleting the SAI pump/disabling the cel with a tuner or an O2 eliminater? Dont need to pass any emmisions tests. Rather eliminate the system and never worry about it again. :)
here are some threads with smattering info about SAI and also maybe egr delete. I assume you need a tune to get the code out. I would contact Paul Nimz, he is SHOZ123 on the forum. He probably remembers modding his genIII more than I do. I never had to deal with it but, if I was going to dig in and needed a tune, I'd probably remove that and cap off the egr too. Drop him a PM as he stops here every blue moon but has moved on to other car platforms.
gamefanatic
Barstow, CA
I have had this before and found if the pump turns on as then its the vaccum switch (EGR Valve Control Soleloid). Usually its the solenoid.
