JrodSVT
So yesterday i go to michigan to pick up the 90 and bring it home (i was going to drive it ) well two days ago the guy calls and said the brake line busted and said it was under the hood so it must've been a steel line. Well he felt bad and offered to trailer the car to me at no charge. I decline and say naw i will come up and fix it. Well i thought being under the hood it must've been offa the HCU. I get there yesterday (four hour drive) and look and see that it is not the HCU but a small mounting block on the fender well drivers side. Well we look at it and decide that it is only a pass through for the ease of installation at the factory. We bypassed it. Next one on the block blew. Well the local pepboys is out of 3/16 unions(we actually used quarter inch on the first one) so there is no luck goin and bypassing the next line. the last line on the Block looks better than the first 2 but not much. So anybody ran into this problem on there gen 1? the block is located just under the brake booster. My solution to the problem is to rip off all the abs and switch it to normal brakes suck as a 89 SHO and use stainless lines.
